Official M2 schematic
Last modifications.
JP
  • PASS_F6_SUPPLY_CRC_SCH.pdf
Joined 2016
Is there a recommendation for film capacitors in parallel to electrolytic ones?
JP
Hallo JP,
I really like WIMA MKP10. Usually use them as signal path caps or bypass in signal path. When I can fit them, I put them in the PSU as well as bypass (often 2.2 µF - 4.7 µF). Otherwise, I try to use WIMA MKP4.
Both variants are large and need to be mounted directly on the PCB, though ... :scratch2:
Viele Grüße,
Claas
