more info
The pre amp is described here:
http://myweb.tiscali.co.uk/nuukspot/decdun/gainclonepre.html
The voltage is specified to 15+ v - but what about 13v....
Thomas
Thomas
The 100k doesn't harm but would do anything either i think.
13V supply should be OK with possible a little less output level - but still enough to wildly overdrive your GC!
This is a buffer (if I got the right diagram on the site) so no gain, I'm afraid. You really need 6dB gain? How about just turning up the vol control a bit further, or rather turning it less far down?
Jan Didden
Jan Didden
Correction: The 100k ensures the output floats to gnd if connected to a capacitor-coupled power amp input.
Beat me to it!
ThomasS, you may find that with the buffer in between the volume control and class-T amp that you don't actually need the extra gain!
Nuuk said:
Beat me to it!
[snip]
Wow! That was close , almost got caught with a mistake.
Jan Didden
The passive line level x-over causes quite a bit of attenuation but I'll give it a try
Then go active! It's not really difficult. If you want to keep with the Les Sage buffer concept, then try these .
Hardly any more work than the buffers and you have your crossover filters as well!
Jan - yes, lucky to corrected that one. I've seen people shot on this forum for lesser mistakes!
Re: PLLXO...
Aha! I was wondering what a Phase-Locked Loop Xtal Oscillator had to do with it....
Jan Didden
ThomasS said:The passive line level x-over causes quite a bit of attenuation but I'll give it a try
Jan Didden
- Class D
- Nuuk's active pre for Si T-amp...
