Noob question about driver replacement
Sorry for the noob question...I registered here because I couldn't find my answer anywhere else.
I have a set of old Jensen JHS 63 speakers; 6.5" woofer, 2.5"ish mid, 1/2"ish tweeter, in a ported cabinet. On both speakers, the mid and tweeter are dead. No sound and no reading when checking resistance.
My question is...since this is a set of fairly cheap speakers that will only be used in my garage...Can I replace both the mid and tweeter with a single 4" 2-way car speaker? Maybe put a high-pass on it at 2khz or so?
Or even just add a cheap tweeter? I was thinking a 1" soft-dome car tweeter, only because they're easily obtained locally and cheap.
I'm looking to get this fixed for as little money as possible.
Thanks,
Bryan
I've attached a few pictures. I don't have any of the drivers right now because I'm at work.
From what I remember, the small tweeter is a piezo and has no markings on it. The middle one fits in the hole pictured and only says "east asia - 4-ohm - 50W" on it. It mounts to the plastic piece surrounding the two upper drivers with 2 tabs. The plastic itself is then screwed onto the cabinet.
Pics of the "mid" driver. I'm not worried about the little 1" piezio thing, it fell apart pretty easily.
I dented the dust cap taking this out...oops.
With those being 8ohms, that'll mess with the impedance my receiver sees, right? The back of it says no less than 8ohms.
XO that's in there now is a 3.3uF capacitor and an inductor of unknown value (no labels anywhere). @ 4ohms, that's about 12khz, correct? Seems a bit high...
