Noob ESL builder looking for advice
Did some home work and made a few calls this afternoon,The Antek trannies AN0506 are out until October, the AS0506 are the 17.00 per will work.
The only difference between the 2 are, the AS0506 has a foil shield purple wire that can left un used...and the 5.00 increase....
Doc
Shaun is good to go but that's great news for anyone else needing trannies. $17 still beats any price out there and we know they sound fantastic.
I am not so sure about the shielded version!
The shielding may increase (maybe even double) the transformers parasitic capacitance.
This is something that needs to be tested before it is recommended as the added capacitance will lower its resonate frequency in to the audio band.
jer :)
Some of these as an example will get you the needed higher transformation ratio using just one core.
They may be good candidates providing their capacitance is not to high.
http://www.antekinc.com/pdf/AS-1T250.pdf
http://www.antekinc.com/pdf/AN-64115.pdf
http://www.antekinc.com/pdf/AS-1T200.pdf
http://www.antekinc.com/pdf/AN-4TK360.pdf
http://www.antekinc.com/pdf/AS-1T300.pdf
I think that they have an Isolation transformer with just 4 identical windings on it and if it is a 240v it would be great.
jer :)
I still think that would be a cheaper way to go.
And still have better performance.
But there are several good candidates from antek that might work and still have a 1:100 transformation ratio, But they are in the $40 to $80 range.
I just compiled a list 3 times and my mouse is acting up and lost it 3 times. :(
This one for $50 would give you 1:75 or a 1:150 ratio with the 1:75 configuration having a lower frequency capability of at least 240hz and 48v peak input for a 150watt ampilfier range and 480hz at 48v peak for the 1:150 ratio,
jer :)
P.S. Oh there is my list we are on a new page now !!! :/
