Just registered as a member of the forum.
You guys are great. I got the bug too and I'm going to build monoblocks based on LM3875. I was deciding on the topology (Inverted vs. Non-Inverted). I did quite a bit of reading and found that people prefer the inverted topology but than (for obvious reasons) they put a buffer at the input. Some claim that that way GC sounds even better. Well the buffer is an OPAMP in a non-inverting mode with a gain of 1. If the Inverting topology has an advantage, why implement it together with the non-inverted (buffer).
You might as well stick to the non-inverting GC on the first place. You'll end up with less components on the signal path, which is the reason on the first place to build the GC. Please comment. I'd appreciated.
Great forum. A lot of inspiration. Thanks!
Greg
Greg
Fully agreed. A resistor in series with, and a cap to ground of the + input, gets rid of the funnies that can happen with the non-inverting configuration. ~ 2.2kOhm and 0.001uF
Hi hitsware,
You are referring to a LP filter at the front of the NIGC (non-inverting GC), right?
I think KIS would be my preference. Non-inverting GC with a 100k pot at the front and an optional RC LP filter as you mentioned would be the best topology IMHO. And if i want to get rid of the NF cap have to make shure I balance the input curents of LM3857 so that it minimizes the output ofset as much as possible. Also I was thinking that one of the reason for difernt sound coud be the difference in value of the NF resistor (220k vs 20k) used in the IGC. So I'll try building NIGC with NF of 220k and 22k to gnd and 22k to gnd from the + of the 3875. It should eliminate the output ouset. At the same time with input impedance of 22k in paralel to 100k pot will turn the linear 100k pot into semi Log. I tried it and it works quite well. This way, only one input cap in the whole circuit. Hope it'll work as I think.
Greg
Greg
GregGC said:If the Inverting topology has an advantage, why implement it together with the non-inverted (buffer).![]()
Greg
Greg: the same topic has been extensively discussed and debated in this forum. As you will find, there is no conclusive and / or emperical evidence that inventing topology sounds better.
The rumored "gains" in THD figures due to common mode rejection are in the sub-micro percentages, at best.
To give you any comfort, most SS amps use non-inverting topology. If inverting topology had that much of an advantage, you would have expected just the opposite.
Just because people believe in things doesn't mean those believes are right and fact-based.
And I am sure you will find a lot of similar things in audio in general and on this forum in particular.
I'm guessing that the buffer is used to drive the lower than normal input impedance of the IGC. Many people are using input impedance of about 10K for their IGC. The buffer could just equalize the system with the 47K impedance of many sources. What I don't understand is if they use an IGC, why not also use an inverting buffer?
🙂ensen.
🙂ensen.
If you use opamp as a buffer it'll have the same disadvantage of relatively low input impedance as the IGC, but at least the gain of the amp will not depend on the vol control. Still more transistors on the way of the signal thogh.
Greg
Greg
GregGC said:Just registered as a member of the forum.
You guys are great. I got the bug too and I'm going to build monoblocks based on LM3875. I was deciding on the topology (Inverted vs. Non-Inverted). I did quite a bit of reading and found that people prefer the inverted topology but than (for obvious reasons) they put a buffer at the input. Some claim that that way GC sounds even better. Well the buffer is an OPAMP in a non-inverting mode with a gain of 1. If the Inverting topology has an advantage, why implement it together with the non-inverted (buffer).You might as well stick to the non-inverting GC on the first place. You'll end up with less components on the signal path, which is the reason on the first place to build the GC. Please comment. I'd appreciated.
Greg
Hi Greg, welcome!
What you say is logical and puts the finger on the right spot. However, you will find out that this is not necessarily an advantage or appreciated at this forum. Still, it's a great place to learn and teach. Have fun!
Jan Didden
Dear Jan Didden,
Thanks for the welcome.
I think that part of the learning process is questioning what we/people take for granted. I may be wrong. I'm new at this forum and I don't mind being advised on what an appropriate behavior for this forum is (mind you I red the rules when I signed-up). I thought, though that we are all open minded individuals that exchange thoughts on how to improve on a great idea. I don't get offended if I find I'm wrong in something. Also I'm not sure I'm right at assuming (read the headline). Otherwise I wouldn't have open the topic for discussion.
Life is a learning process.
Greg
Greg
Re: Re: Non-Inverting GC BETTER than Invertin GC+Buffer?!
Thanks for your input. What do you think about my prvious message descibing the circuit I'd like to use (No NFB Cap)? I still don't know how to post pictures/diagrams.
Greg
Greg
moamps said:From NS LM4780 datasheet;![]()
Thanks.
As far as the size of the NFB capacitor, why not use the NFB resistor values instead 1k/20k/10uF use 10k/220k/1uF. This way the NFB cap is 10 times smaller in value. I'm not too crazy about totally removing it though. And as far as noise level it'll be the same as IGC implemented with the same NFB resistor values (if I'm not missing something). The advantage: constant gain, disadvantage: one extra cap (this way at least the size of the cap 1uF alows using a better type rather than electrolitic one)
Greg
>If inverting topology had that much of an advantage, you would >have expected just the opposite.
Not necessisarily because of the obcession with "absolute phase"
As far as absolute phase all i do ,on the GCs that i sell,is swap the polarity on the speaker posts on the inside of the cab,ends a lot of confusion.
ron
ron
hitsware said:Not necessisarily because of the obcession with "absolute phase"
"absolute phase" is another audio "urban legend" that can be easily addressed either by the designer or the user, as ron had mentioned.
It may be an "urban legend" to you, but I can easily detect the difference when changing speakers polarity with my GC amp. So it seems some other forum members.
http://www.diyaudio.com/forums/showthread.php?s=&postid=160948#post160948
True, true, but not always satisfactory to (some) customers. I'm working on an inverted design right now, and know the guy's gonna not like the idea of hooking up his speakers backwards. I also know he can hear the differance...........mike
Peter Daniel said:It may be an "urban legend" to you, but I can easily detect the difference when changing speakers polarity with my GC amp. So it seems some other forum members.
Unless and until they are proven to be able to hear the differences, I am going to trust all the claims as any other claims.
hitsware,
They don't have to know that the speackers are reversed. You connect the red terminal to gnd and the black-one to the amp's out inside the housing of the amp. On the outside everithing looks right (not that anything is wrong anyway).
Greg
Greg
I must agree with Peter if you can't hear absolute phase you may have a earing problem.
I claim to have no golden ears, although maybe I should since I have been very disappointed by several project that are given a "divine" status on this forum, nonetheless, time after time I detected a reversed polarity by ear after mistakenly connecting the speakers.
grataku said:I must agree with Peter if you can't hear absolute phase you may have a earing problem.
it is not if you can hear absolute phase. It is if you can hear two different set-ups:
1) a non-inverting amp driving a speaker;
2) an inverting amp driving a speaker with terminals inverted.
Now, who claims to be tell (hear?) the two apart?
- Chip Amps
- Non-Inverting GC BETTER than Invertin GC+Buffer?!
