Nippon Chemi-Con site
www.chemi-con.com
Halo search: with google
http://www.google.com/search?num=30...n+capacitors+SMH+data&btnG=Google-sökning&lr=
grimberg
seconds faster ....
than halojoy
Here is a PDF, 197 pages !!!!!
http://www.europechemicon.de/ecc01/Main/al-all-e1001a-010928.pdf
From this list:
http://www.europechemicon.de/ecc01/Products/aluelco/aluelco.htm
www.chemi-con.com
grimberg
seconds faster ....
than halojoy
From this list:
I used this brand of cap in my Aleph 2 power supplies, X4 each. I was able to get mine surplus for 10 bucks each with mounting flange. 56,000uf @ 63 volts.
Anyone need any call Ra-Elco in Slat Lake City as they have a ton of them available...at least as of the last time I ewas there. Funny thing though is that mine don't ahve the standard markings on them as far as part and ID numbers but they are stamped 95 deg. C. , the value above, and the date code which is 9743C97. You can contact them at 801-487-7749. Ask for Robert.
Mark
P.S. I don't work for them and am not associated with Ra-Elco in any way. I just buy alot of stuff from them for these projects and they are nice guys and very reliable!
Mark
The place is called Tanner Electronics. They are in Dallas (well, Farmer's Branch if you want to get picky).
100 Valwood Pkwy.
Dallas, Tx.
(972) 242-8702
On the web here: http://www.pc-cables.com/
but the web site doesn't tell you anything useful except the address and store hours.
They have a bunch of other caps that would be good for amps as well.
MR
100 Valwood Pkwy.
Dallas, Tx.
(972) 242-8702
MR
- Design & Build
- Parts
- Nippon Chemicon cap specs
