Retro 800watt quasi retro amp on ebay.
Limited edition 800watt quasi complimentary amplifier.
800w quasi retro amplfier kit module 4 disco band PA on eBay (end time 23-May-10 01:48:29 BST)
New amplifier module web shop
1600 watt into 2 ohms MOSFET power amplifier
On ebay:
1600 watt amplifier module band DJ PA on eBay (end time 24-Jul-10 16:03:23 BST)
On ebay:
1600w hybrid amplifier module.
1600 watts valve hybrid amplifier module.
Very rare 1600W valve front end power amplifier module on eBay (end time 02-Aug-10 00:22:38 BST)
PCB Design software on ebay
128 layer autorouter. Design rules checking.
PCBCAD40 pcb CAD printed circuit board design software on eBay (end time 17-Jul-10 00:52:26 BST)
Valve MOSFET hybrid amplifier module on ebay
eBay - The UK's Online Marketplace
SRPP valve stage.
LTP with CCS and CM, Vas with CCS and Vbe multiplier.
MOSFET output stage.
SRPP valve stage.
300 watt MOSFET amplifier on ebay.
300watts peak into 4 ohms.
LTP with CCS and CM, VAS with CCS and bias, complimentary MOSFET output stage. Clip LED driver
New 300 Watt Amplifier module 4 disco guitar band PA UK on eBay (end time 09-Dec-10 22:05:58 GMT)
Also see 300 watt valve front end MOSFET amplifier.
Very rare valve MOSFET hybrid 300 Watt Amplifier module on eBay (end time 22-Dec-10 02:08:59 GMT)
Amplifiers and PCB software on ebay.
Various class D and class AB amplifiers and pcb design software on ebay.
murtonpikesystemscarlisle items - Get great deals on Consumer Electronics, Business, Office Industrial items on eBay UK!
Cheaper IR parts
I hunted around for the vendor with cheapest IR parts such as IRS2092, IRFB mosfets etc and found this vendor to be very good.
They are definitely worth supporting.
Electronic Components from the Best - Future Electronics
I have no connection with them other than being a customer.
PCB software and amplifier modules for sale on ebay.
Any schematics of the mos fet valve hybrid?what kind of transformer does it use?
What do you use for outputs?
Any measurements?
The schematic is simply an SRPP valve stage followed by an IRS2092 circuit as per datasheet. It requires a 500va transformer.
It uses irfb4227 output mosfets.
- Vendor's Bazaar
- Nigel Wright's Vendor Thread
