OK, I promise.....As long as you don't post diagrams resembling your avatar we'll manage.
Joel,
I haven't asked others, but the reason I've not used 12AX7, is the gain. They've only been suitable in designs with lots of feedback. Could that be the reason?
Joel,
OK, to clarify, I didn't mean that a valve with high gain is a bad thing. It's just that in the designs I've done in the last 8 years, I have not found a place for such a device.
Those amps have been low or no feedback.
I was speculating that others who use similar design lines might have found the same thing.
I have no grudge against 12AX7's
A NON-COMMERCIAL DIAGRAM
nice with tube schematics
you don't get a severe headache by looking at
Thanks for that diagram! I have saved it on my disk for eventual future use.fdegrove said:A NON-COMMERCIAL DIAGRAM
Just what the doctor ordered?
Ciao,
Robert, a good Aussie site for valves is www.evatco.com.au
I have got several orders from them, they seem to be pretty economical and speedy.
~h~
~h~
Hi everyone,
I like this forum idea!
Much better response than I expected.
I don't even have to ask questions and I get answers to them.
fdegrove - Frank is it?
The ciruit you provided is exactly what I had in mind.
Where did you find it?
I will check again later, then I will go home for the weekend and ponder these suggestions.
And I will see if I can come up with some sensible questions for next week.
GLAD YOU LIKE IT.
Hello,
It's one of those circuit I helped out of the door but that's a long story.
No idea how it landed on the web.
Here's where you can find it + some more info:
PP KT 88 UL
It's pretty mature but everything can be improved when the dollar is no object.
Enjoy,
Hello,
PP KT 88 UL
Enjoy,
Some questions
Hello
Power Supply
There are many varied opinions.
I think that the general consensus is that if you have a power supply capable of supplying the demands of the amplifier, that is suitably filter with a good LC filter, it doesn't matter what you use.
So I think I will use diodes, a pi type filter (CLC) with a reasonable capacitor on the output.
I have read in another post about 'stand-by' or 'delayed turn-on'
and I get the impression this is not good.
What about a slow start circuit?
Tubes
Matched pairs - pros & cons?
Are they nessesary with fixed bias?
I intend to use fixed bias on the last stage.
Hello
Power Supply
Tubes
This might interest you.
http://www.pmillett.addr.com/push-pull_kt88_class_a_amp_with_universal_driver_pcb.htm
G
G
DELAYED RESPONSE...
When you choose silicon rectification a delay on the B+ wont hurt
(say 10 secs).
A tube rectifier does that automatically though.
However,what is just as important to preserve the tubes it to provide for a quick discharge path of the PSU when turning OFF.
Otherwise the same problem occurs!
That is assuming you want to preserve the tubewildlife....
(say 10 secs).
- Tubes / Valves
- Newbie's 1st Amp, comments please.
