Newbie design
Hi.
I am new to speaker building so I want my first project to be mainly a learning exercise.
Therefore I have decided to try and make a Subwoofer out of parts I already have.
A friend recently gave me a set of speakers with 12 inch Dai1chi 120 watt speakers, plus I have a couple of reasonable quality 300 watt stereo amplifiers, so hopefully I can make something that doesnt sound to bad.
I would like some advice on what would be the best way to go:
Sealed or vented sub?
Dual 12inch drivers in one sub or two small subs?
Any existing plans that you know of that may be suitable would be greatly appreciated.
Mike C
After much searching, found the following info on the drivers
(Made a mistake in my last post-100W not 120W)
12" WOOFER 100W
Paper Cone.
Foam Surround.
Z 8W (7.2Wdc)
Freq. 33®4KHz
Fo 32Hz
Sens' 93dB
Magnet 30 Oz
Voice 38mm
Power 100W nom.
Qms 1.42
Qes 0.47
Qts 0.35
Vas 188.56L
Code SP12-100
12" WOOFER 100W
Paper Cone.
Foam Surround.
Z 8W (7.2Wdc)
Freq. 33®4KHz
Fo 32Hz
Sens' 93dB
Magnet 30 Oz
Voice 38mm
Power 100W nom.
Qms 1.42
Qes 0.47
Qts 0.35
Vas 188.56L
Code SP12-100
some alignments for one driver, :) sreten.
JMO but a single 300w amplifier is way more than enough,
IMO you'd be a lot better off with the facilities provided
by a mono plate amplifier circa 150w for both drivers, e.g. :
http://www1.jaycar.com.au/productVi...&pageNumber=&priceMin=&priceMax=&SUBCATID=443
Note that an isobaric pair will be 1/4 of the size of a pair
used in parallel, but maximum output will be 6dB lower.
IMO the isobaric ~ 2 cuft ~ 60L tuned 30Hz looks good,
unless a big box is not a problem, then ~ 6cuft ~ 200L
tuned to 28Hz, drivers in parallel is the way to go.
:) sreten.
Thanks steren for the info, much appreciated.
A couple more questions:
With the isobaric option, does the box volume stay the same if you dont have the drivers configured in a clamshell arrangement, instead have one behind the other (cant remember what they call this config)?
Also I was trying to match your results by putting the driver info into WinIsp but my results never seemed to match yours- mainly in the single driver option- box always came out at 118 ltrs- This is the first time I have used this program so I guess I am doing something wrong or misinterpreting the driver data.
Can you show me the data you entered into the driver parameters?
Thanks again.:)
