new Trannies
Hi Folks,
got me some new toroids 230V/2x6V, 50VA. Wired two of them in series (230V) and parallel (6V). This gives a factor of theoretical ~1:75 (in praxi it measures 1:68)
Here are first measurements of my panel (1.2nF) connected to these toroids in nearfield (10cm) (Spl is recalculated to 2m)
As one can see linearity is very good. The upper bandwidth is well above 20kHz (mic´s not compensated for and starts to roll off beyond 15kHz).
jauu
Calvin
  • rk 1_68 10cm amp 251105.pdf
Hi Folks,
the impedance plot prooves the high bandwidth. Plots are nearly identical to those measured with the 1:75 Amplimo. The resonance of trannies stray inductance with the panels capacity is above 20kHz.
Conclusion: Even with high capacitive panels simple and cheap toroids work and they work better than lot of so called specialized audio-trannies!
jauu
Calvin
  • rk 1_68 10cm imp 251105.pdf
I measured the Avel Lindberg 50VA 115x2 : 6x2 transformer this morning (part number Y236200, two wired as above).
Effective turns ratio measures and calculates to about 68:1
The leakage inductance looks good, the effective secondary inductance looks not so good.
For leakage inductance (secondary, high impedance side) I get about 28 mH, which is good.
For effective secondary inductance, I get about 5.3 Henries. This is not so good, making to difficult to design a passive crossover, and being problematic for direct coupling to an amplifier due to low impedance at low frequencies.
Effective secondary capacitance is about 1200 pF.
The impedance curve shows a peak impedance at about 1400 Hz when loaded with 1000 pF. This is quite a bit higher (in frequency) than shown in the impedance curve above.
Apparently not all cheap toroids are built the same.
For comparison, the 75:1 Plitron ESL transformer specs are:
22 mH leakage
1600 Henries
800 pF
This transformer provides a very good higher impedance at low frequencies.
Another comparison, the E R Audio ESL transformer (my measurements):
22 mH
64.8 Henries
308 pF
Distortion measurements would be very interesting ...
I doubt the core of cheap toroids is made of wrong steel and plates are badly isolated between each other.
Also , what do you think about taking one of secondary windings and making additional feedback to amp ? Wouldn't it decrease distorition caused by the transformer ?
Hi Folks,
first let me introduce myself. Since 15 Years I am an ESL enthusiast and gained some experience by building more than 50 iffernet types of ESL.
regarding toroids it needs to be said that standard transformers suffer from disadvantages as follws:
1. There is no insulation between the layers of the secondary winding. Additionally cheap transformers do not use double insulated copper wire. This means that there is a high potential of electrical short cut of the secondary winding depending on output voltage. The tested voltage handling capability is just true between primary and secondary winding.
2. The missing insulation of the secondary winding increases internal capacity of the secondary winding, which is contra regarding step-up ratio. In addition cheap transformers are wound very lousy,leading to crossing wires (results in additiional capacitance and short cut potential)
3. Typically core material of standard transformers is ferrite and not oriented and heat treated silica. Ferrite has its limitations regarding saturation and more important harmonic disssortion of the signal. Those ferrits are not designed for frequencies up to 20Khz.
In summary, toroids are really a good choice, but need to be specifically designed for ESL as well as EI or M-Types.
Do not expect miracles from cheap standard transformers.
Regards, Capaciti
I don´t claim the standard toroids to be superior to specialized toroids, but since the built is similar it was worth giving them a shot. And the results are very promising even with high capacitive panels in ML-style.
The backdraws Capaciti mentioned are true, but do they count in praxis?
1. Is special insulation on the secondary necessary? If the secondary is the low-voltage-side, than the answer is no. On the high-voltage-side it depends on the needed voltage-levels of the panel. Highly capacitive high-efficiency panels don´t need much voltage, and if the primary is wound in just one turn, the problem doesn´t appear anyway. We do need high dielectric strength between primary and secondary windings and this we have.
2. Is it of interest, when the reached transformation factor is sufficient? It seems that 1:75 could be limiting border for standard toroids. With even higher transformer ratios the demands will probabely too high.
3. Typical core material of nearly each power transformer I found on the net is grain orientated material with 0.3 to 0.35mm thickness. Anyway everybody can look up datasheets
In summary, within certain restrictions I see no reason not to use off-the-shelf standard toroids. The measurements I made with my panel showed an astonishingly close similarity to the excellent Amplimos but to app.1/10 the cost.
Still, I don´t expect wonders from these Trannies, but they are imo much closer to that than specialized and overprized ones :cool:
jauu
Calvin
Hi BillH,
really compelling pricing !
This transformer is small in size and has a limited core area. My guess is, that this transformer will show saturation if you go lower than 200-400 Hz (depending of input level).
It would be interesting to get some feedback from your trials with this size of toroids.
Whats the secondary output voltage required for appropriate sound pressure of your Panels ?
regards, capaciti
Capaciti writes:Whats the secondary output voltage required for appropriate sound pressure of your Panels ?
I haven't figured that out yet as my ESL panels are still a work-in-progress at the design stage. Here's a
DIYAudio forum thread with some of my plans. Lately I've been considering panels with two 5" x 36" bass sections and one 2" x 36" treble section, with capacitive crossover between the sections.
Capaciti writes:This transformer is small in size and has a limited core area. My guess is, that this transformer will show saturation if you go lower than 200-400 Hz (depending of input level).
I'd like to try testing one of the transformers using the circuit below. This should let me plot frequency response of the transformer at different voltage levels and get a look at what point saturation sets in.
Edit: I should add a capacitor across the output of the transformer to simulate the ESL panel.
Hi Folks,
i like to show you the measurement of an toroid designed for ESL.
The step up was connected to 1,2nF. As you can see the impedance graph looks nearby identical to the graph of calvin's step up. Phase shift is at 20° @ 20khz as well, indicating that stray resonance is above 20 Khz. The parallel resonance is lower than 400 Hz due to larger primary inductance. As a result this step up transforms even lower frequencies.
But what is most interesting is the fact that this step up has a turn ratio of 1:100, which means about 3 dB more efficiency of the ESL compared to a 1:70 ratio.
The secondary windings of this stepup are optimized regarding lowest capacity of the winding, enabling higher turn ratio.
In summary standard toroids work, but are easily outperfromed by dedicated ESL-toroids.
Regards, capaciti
Hey Bill,
I also purchased 4 of these torroids for my ESL project. I will be watching this thread carefully to see your results.
I bet there are more poeple on here who have purchased these torroids given the fact that the link has been floating around here for a while and the toiroids are now sold out.
furly
How do you get a 115v primary up to a 230 v primary in part #y236200?
The Avel Lindberg 50VA 115x2 : 6x2 transformer has two 115v primaries that can be connected in series (thats 230v total). Connecting two of these transformers together, the 6v sides in parallel, and the 115v sides in series, gets the 68.57:1 turns ratio.
This is using the Avel Lindberg specifications for this transformer, including the regulation specification.
Again, I find this transformer unsuitable for an ESL due to the low effective secondary inductance (equivalently, low effective primary inductance). There are better options, I am sure.
you mentioned 5,5 henry secondary inductance for part #y236200, which means about 1 mH primary only.
This is far too low to achieve transmission lower than 400 Hz
It may be useful for an electrostatic tweeter, but I wouldn't recommend it even for that.
capaciti, you had posted an impedance curve for a toroid designed for ESL. Who makes it? Any further info on it?
Hi goudey,
i don't know if advertisement is appreciated in this forum, but as you ask me i will answer your question.
Capaciti is a german manufacturer of ESL and components for ESL-DIY.
Currently we are just focused on the european market, but working on a disribution strategy for worldwide as well.
We will than offer stepups, power supply and possibly our ESL-panels.
The stepup in the picture has 4,33" dia and 2,08" height and handles 30V input @ 100 hz. Both secondaries are on the steup, so just one is needed. Different steup ratios are avaiable.
The power supply is assembled and adjustable from 1000-4000V. it features a remote on/off for high Voltage, driven by the audio signal from the amp. It turns on at 0,4 Volts and turns off after 20 minutes w/o a signal. Its fed by a 110/9 VAC wall plug supply.
Currently pricing is under calculation and will be about 70-80 USD for the stepup and 50-70 USD for the supply.
If you want, take a look at
www.capaciti-diy.com
Its just in german language, but english will come soon.
Capaciti
  • stepup+supply.pdf
Hello,
I have one idea floating in my head - what about making additional feedback to amp from transformer's secondaries ?
Is it possible , and , if yes, has anybody tried that ?
I think LM3886 chip amp would be perfect for experimenting.
Adding a schematic as i imagine it ...
Lukas
