New tools
If you want to buy your last soldering iron first, get a Metcal SP200 and call it done. Ebay it... $80 - 120. Then buy tips.
For your first real meter, get a fluke portable... like a Fluke 80, 83, 87.
For your second meter get a bench model and spend the $$ HP34401A's are good ($1200+) Older HP like Jackinnj mentions are good too.
AKN
Joined 2005
edjosh23 said:
4fun,
You said your new iron has "electronic temperature regulation", does that mean you have the wesd51 ? How does your new iron compare to the WTCPT?
Thanks,
Josh
That's too new :) my gear today is WECP-20, electronic control with connection for esd protection.
Comparison, hmm.
Reliability is much improved with electronic control. The mechanical thermostatic switch could get stuck on old WTCP. Another obvious advantage over old WTCP is choice of tip temperature over a wide range.
