ELEKIT TU-8100 Siemens PCL86
New Low Price $299.99
[specifications]
●Vacuum tube: PCL86 (14GW8)X 2 Siemens
●Output: In 2W +2W (THD=10%, 1kHz, 6 Ω load)
●Input: 500mV (INPUT-1: RCA jack)
: 150mV (INPUT-2: a stereo minijack)
●Residual noise: 40μV (IEC WEIGHTING))
●Frequency : 23Hz - 33kHz
●Speaker impedance: 4-8 Ω
●Output terminal: Binding terminal
●Power supply voltage: AC100V 50/60Hz (3P inlet)
●Main body power supply: DC12V 2A
●Dimensions: including the W142 X H136 X D178mm
●AC adapter: AC100 - 240V (50-60Hz)
●Weight: Approx 1.8 kg
Option : Automatic Shut off option
Option : USB-DAC
[specifications]
Option : USB-DAC
