Possible solution in my case
@ Jason
If you look into the profile of "Klang Projekt" in my special case, he joined on 7th December 2004 and made only 5 posts.
Perhaps you could send him a PM, ask him to start a new profile and cancel his actual!?
If i understand you right, that will fix my problem.
Another path is to delete the "other" user, if they are not active on the forum anymore (say within the last 5 years) and never posted.
@ Jason
There is still a chance of a redirect. I believe what Jason suggested was for you to accept your username without the dash. I am about to do an experiment and will report back.
OK, that works fine so I will send you an email to confirm.
All runs perfect again! Thank´s Cal.
Still some problems
@ Cal
I have still a problem with my "Blog Categories".
The local category "Offer" goes still to Klang Projekt and the "Stax High-End Headphone Amp" is liked to the "First Watt F5"...
If i click on my nickname in my blog, it goes also to Klang Projekt...
@ Cal
When I go to Blog catagories Offer it goes to Tube-I-Zator V3.0 not Klang so maybe clear your cache and try that one again.
I also get FW 5 on the Stax one so I suggest you remove that entry and repost it.
It was the cache...
The blog entry is still there:
http://www.diyaudio.com/forums/blog...-amplifier-stax-electrostatic-headphones.html
I don't understand. When I click on your name then view blog, I get this:
If there is trouble with the links then you are the one to remove and repost.
As i wrote, it was my cache...
The only thing left is the Stax link. The blog entry is still there:
http://www.diyaudio.com/forums/blogs...eadphones.html
Get rid of that and repost a new link. If you can't do that, then we needs Jason's help.
Done
I got a complaint nobody can see the inline images on my blog.
diyAudio - Tea-Bag
They are linked from my gallery. I look in the gallery, they are there. here is the full link
http://origin.dastatic.com/forums/gallery/data/1774/medium/F6UMS3.png
I clicked on the pic's and I get this report.
Not Found
The requested URL /forums/gallery/data/1774/medium/F6UMS3.png was not found on this server.
Sorry if I have not read every post on the matter.
diyAudio - Tea-Bag
Not Found
- Site
- Forum Problems & Feedback
- New bugs
