thanh: do you men 1 ohm res on the voltage amp transistor's emmiter
I guess these is just small enough change it to zox's value which is
33 ohm . dont forget about the emmiter internal resistance (re)
33 ohm is a good value to compensate with this one.
expect sonic changes when you try to change resistor values.
try 68ohm, 56ohm, 47ohm, down to any value available.
regards,
hienrich
regards,
hienrich
- New Amplifier 95% done-what do you think?
