the monoblocks are 164mm (H) x 248mm (W) x 263mm (D) excluding binding posts.
I used the Conrad MF250-151.1 heatsinks (D= 250mm heatsink, 10mm front panel, 3mm rear panel), which seem to give adequate cooling but have meant that the interior is kind of tight. I'd originally planned to use a 300Va transformer but went with a 500Va. Because of the additional height of the larger trafo I couldn't mount the main amp board above the psu as planned, and have had to mount it onto the rear panel. The layout is less than ideal but seems to work ok.
cheers
Paul
cheers
Paul
Switches
Hello All,
While you are busy chatting about your Aleph 30 amplifiers, have any of you chosen attractive looking, high quality power switches - preferably from Digikey, because they ship efficiently to Australia, and I am going to do another order from them soon (or I guess from Farnell who are reasonably well organized locally.)
My next project is to be some Aleph 3/30/Babelfishs and I think it about time I put on-off switches on my amplifiers, rather than just using the wall power switch.
They have to be "nice looking" and "high quality" because I am going to be cutting into my black anodized front panels (something I have avoided so far) and I would like them either to last a long time or be reliably replacable without having to re-cut the front panels of my cases.
George.
Hello All,
George.
Re: Switches
http://www.apexjr.com/miscellaneous.html#Other
http://www.apexjr.com/components.html#Toggle
GeorgeBoles said:Hello All,
George.
Re: Re: Switches
I order and use the crap out of the first one he posted, but beware the contacts are VERY tiny so large gauge wire will not fit.
But the action is very good and they are pretty if you find beauty in such things.. I do.
FYI: I ordered more boards for the mini Aleph amplifier pcb set, and also the big power supply boards. They are $9 each. More info here:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=98892
They are black with gold plating this time.
Brian
Brian
Banned
Joined 2002
BrianGT said:FYI: I ordered more boards for the mini Aleph amplifier pcb set, and also the big power supply boards. They are $9 each. More info here:
Brian
thank's Brian.
Banned
Joined 2002
adwsail said:FYI, You might want to stay away from the SMT boards. I have 2 of them for sale at cost (Brian's boards). I can't get the IRF9610 in a SMD package unless I order 250 of them. The boards are beautiful but useless to me.
That's not true, I got mine from Digikey, I am running 4 smd boards.
Digi-Key Part Number IRF9610S-ND
Price Break 350 Unit Price1.18200 Price 413.70
Manufacturer Part Number IRF9610S
Description MOSFET P-CH 200V 1.8A D2PAK
Quantity Available
All prices are in US dollars
Digikey won't let me order less than 350 units. If you have 6 to spare I would like to order them.
Quantity Available
Banned
Joined 2002
adwsail said:Digi-Key Part Number IRF9610S-ND
Quantity Available
I wish i had some spare i would send them to you for free, unfortinatly i don't . You could pm BrianGT he might have some.
DigiKey is just out of stock.. Try Newark.
http://www.newark.com/jsp/Semicondu...ER/IRF9610SPBF/displayProduct.jsp?sku=58K5801
or the non-ROHS compliant (and more expensive):
http://www.newark.com/jsp/Semicondu...IFIER/IRF9610S/displayProduct.jsp?sku=07B1546
Banned
Joined 2002
Don't be afraid to ask me any questions about the smd version.
Jase
Image here
http://www.jasesspace.com/G2/main.php?g2_itemId=367
Jase
Image here
C1 on new boards
I just recieved a beautiful set of BrianGT boards and just finished reading entire thread, now the questions.
(1) Are the new boards (black) corrected for C1 cap polarity direction?
(2) Can anyone recommend/explain a working grounding scheme for this project? (newbie so detailed info is helpful).
(3) Can anyone post a picture of ac inlet/fuse/thermistor setup?
Thanks in advance.
Pathmark
Thanks in advance.
Pathmark
C1 on new boards
Thanks in advance.
Pathmark
Thanks in advance.
Pathmark
- New Aleph Mini PCB GB
