Re: tell us...
symetric 50 to 70 volts
sakis said:whats your rail voltage and power that you want out ofthe amp
Of interest: http://aussieamplifiers.com/lateral.htm ... note cross reference to alternate part numbers / makers ...
FastEddy said:Of interest: http://aussieamplifiers.com/lateral.htm ... note cross reference to alternate part numbers / makers ...
give me nx500ln schema ?
" ... nx500ln schema ? ..."
The AussieAmplifiers.com NX500LN is not available as a kit (yet) ... as completely assembled modules only.
The basic schematic is not too hard to figure out if you have a module in front of you ... but the designer rightfully wants to protect his specific ideas with regard to his work and efforts to produce a quality piece of engineering. There may be several sources for "generic" FET input, all FET power MOSFET designs out there ... google 'em ...
- needed n channel mosfet amplifier
