Ok started thinking about what I have and what I may get.
1) I have an amp that currently runs 6x9's w/mids. This amp is 4 ohm stable.
2) I also have a truck box with each compartment having 1 sub and 1 tweeter. They are currently wired in parallel.
How does a tweeter affect ohm values? The tweeter says 4-8 ohm impedance. If I leave the current config for the truck box will the total impedance be 2 ohms or 4 ohms (sort of confused on this since they say tweet are dynamic)?
Since I am in the market for a new amp to run the subs - should I focus on the 2 ohm aspect which gets you more power, or is it a moot point with the tweeter in parallel, and just look at the 4 ohm values?
If the tweeter does not affect overall ohms could I wire the tweeter to my 6x9's in such a way that I will not blow the amp (amp is 4 ohm stable)?
Thanks!
Thanks!
OK, I think I figuered it out. Would this work?
I have 2 6x9's (4 ohms) and 2 bullet tweeters (4-8 ohms). The amp, as I mentioned is 4 ohm stable. Thanks!
Not sure you can do it into a bridged mode but if you have a 2 channel amp and want to keep a 4ohm load (Not so sure on adding in the tweeters and stuff but this is for the subs) I found this on Crutchfield's site...Also depends on if you have Single Voice Coil or Dual Voice Coil subs:
http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?imageID=4SVC_8-ohm_2ch
More wiring diagrams:
Its a two channel amp so I assume its 4 ohm stereo stable. I was talking to someone about this and they said since tweets draw very little system power, that if I wire the 6x9's and the tweets in parallel that the difference would be so minor that the amp would still operate. Is this correct? Thanks!
with the way your diagram is layed out, you would be running eveything in mono.
id go with stereo left and right and wire a 6 x9 and a tweeter in parrallel for each channel.
wire to the 6x9 first, then to the tweeter.
2 x 2 ohm stereo is the same as 4 ohm mono.
technically it would represent a 2 ohm load per channel....but the current draw of the tweeters is low enough that it is usually negligible...except in the case of some piezo tweeters.
experiment with different values for the capacitor values for the tweeters also: 2.2uf, 3.3uf, 4.7uf, 5.5uf, 6.7uf
Thanks! What happens if I run the config in parallel but put the tweeter first? The reason I ask is that the 6x9's are at the back of the cab and I was going to install the tweets in the dash.
One more question, any ideas how to plug the tweet holes in the truck box? I'm just going to run the subs. I was thinking to just cut a piece of wood slightly larger than the hole, and glue/seal it in place. Thanks.
Oh, and how much polyfill should I initially start with? The box is slightly smaller than the specs for the new subs and I don't really feel making a new one. Thanks again!!!
actually you can run it to the tweeter first....but make sure the wire to the 6x9 is a full signal and not cutoff by the capacitor on the tweeter.
plugging the hole should work the way you stated, but id do it from the inside so it wont look to ghetto.
not to sure on the polyfill, but it shouldnt be packed to tightly.
- General Interest
- Car Audio
- Need some help on speaker config
