I can't find the company listed, let alone a diagramme of the pre-amps. Work your way through it by using the valve types and pinouts to work out what voltage you need. The smoothing capacitor will give a good clue. Normally the voltage rating is 30% more than the HT presented to it. AC heaters of either 6.3 or 5v depending on the valve types.
