Need recomdations on a lineamp
fdegrove said:
Almost any medium µ tube will have too much gain already and quite likely too high Zo as well.
So why not get creative with the like of 12B4A, 6S4, 6C19P and such?
Cheers,;)
or better yet use a transformer... why reinvent a bad sounding wheel??? what next differential Srpp's? split load inverter DC to dual cathode followers???
a pair of 6C45's and a surplus toroid will cost $30, allow a 2V input for full out and fall below 300 ohms, that leaves some money for the rest. (assuming you pay yerself a nickel an hour for time spent)
seems like that solves all the problems...
dave
fdegrove said:
What part in my suggestion would be bad sounding, David?
Or am I misreading you?
A ton of paralelled 6DJ8s a la CJ perhaps?:rolleyes:
Cheers,;)
well the 12B4 has an Rp of 1K... we need 300 ohms balanced... how do you get creative and get there?
the 6C19 is like a 6AS7.... the Rp is what 400 ohms and thats when running 100ma.... and the gain is what 2-3??? so you need 5V plus input to get to the needed 30V p-p out...
so i suppose you could use a pair of 12B4's coupled somehow to the 6C19's with a bit of feedback to drop the Zout to the needed value and still meet the required specs with only a quarter an amp of plate current. ;)
as for the paralleled dj8's ... don't you know they sound blurred.
dave
diyAudio Senior Member
Joined 2002
O.K. I see where the confusion comes from....
We actually have two members here with different requirements for the preamp: Woody and Fuling.
You know I was only mocking a certain High-End manufacturer.:goodbad:
Cheers,;)
