65blkbkgt said:So how do I know if the trim cap is bad? I have another radio just like it I can change switch them.
you can try that but if it is a good one i wouldent mess it up
65blkbkgt said:If you have enough interest in something the answers are all here on the internet.
I'm SO glad I found this forum!
try this do you have a chip around like a well try in google do a search for a lm555cn it will give you the spec. sheet in pdf file of any component
65blkbkgt said:I have a cap meter I've never known how to use (if you can imagine that). It's a nice one made by Tenma.
that is the brand i have if you don't care if you take the other radio apart take one out solder so small wires on the legs and on your meter there should be two slots put the range on the lowest uF setting and insert the legs in the meter and see what you get the measure the one on the bad radio and compare
65blkbkgt said:You had to go and suggest I do that search. Now I'll want to stay up ALL night looking for stuff! Ay ay ay........
Danger Will Robinson, DANGER!
i know i have over 1000 chips around here been there done that got the t-shirt
The lowest setting is 2UF. Then it has a black wire and a red wire with different slots on the bottom of the face of the meter.
are they marked Cx above the slots and 2uF is what you need those caps are in pico farad and nF is too low that is nano
Okay........I'm old enough to know that it's time to go to bed and digest the information you've been so generous in sharing with me.
I'll be back at it tomorrow and test that cap with the meter and let you know the results.
I hope you won't mind if I ask you questions (like ****loads of questions). Like "cycle the tuner"?
no not at all glad to help you can also e-mail me at chris_schibik2000@yahoo.com any time
- General Interest
- Car Audio
- Need Help With Early 60's Transistor Radio
