Need help trying to wire a Bluetooth receiver to a usb connector. The bluetooth has a 5volt wire, two grounds that are pigtails and left and right output. Most usb pin outs I have seen only show 5v,ground,+data and-date. I have no idea how to wire this other than hooking the power and ground, any help is appreciated,with drawing doubly appreciated, in fact this would bring you to God status
You say you have left and right wires, that implies that the output is analog, which USB won't work with, it needs digital data. You'd need a codec to convert analog audio to USB.
Something like this: Amazon.com: BEHRINGER U-CONTROL UCA202: BEHRINGER: Musical Instruments
Solder RCA plugs to the the Bluetooth module's left/right/ground wires, plug into the UCA202, plug that into USB.
