Ive had this problem now for a long time but I just got fed up with it.
When my 4 channel amplifier (Infinity Reference 7541a) is on, it always emits constant static/crackling noise that seems to change in volume slightly in my rear left speaker. Once I turn up the volume it is not as noticeable, but when the volume is turned down, you can hear it crackling and hissing. Also, the rear left speaker pops loudly. At first I thought it was random, but yesterday I increased the motor RPMs while it was popping and the pops also seemed to speed up.
Why would it be doing this? At first I thought the rear left speaker channel of my amplifier was failing, but when I noticed the pops speed up when I increased the engine RPM, it made me think again.
Edit: Now that I think about it, the popping sound speed may have gone up when i accelerated because the alternator output voltage may have also gone up and the amplifier received a higher voltage.
If you believe that the voltage has an effect, you need to confirm that the voltage is indeed changing. You should also try to affect the noise with the engine off. Turn various accessories on/off to make the voltage drop.
This type of problem (not necessarily voltage related) happens when capacitors leak electrolyte onto the circuit board. It also happens in older equipment when transistors begin leaking (electrically) but this amp isn't old enough for that to happen.
I think the problem got worse. I had not noticed what I heard today before. When I turned on the amp and head unit, at very low volume, everything seemed OK, but as soon as I raised up the volume, the sound would start to garble/jumble/mix/distort. Eventually I turned up the volume even higher and then it stopped having the problem. I went for a drive and even shut off the car for about 20 minutes and the problem didnt occur again. I didnt notice the popping noises today, but the hissing/crackling was still there.
I disconnected both front and rear RCA cables from the amp and the hissing/crackling was still there on the left rear speaker. This leads me to believe the problem is in the actual amplifier or theres a problem with the speaker (and/or wiring), but I doubt the symptoms I've had are from a bad speaker.
Here is a video I recorded with my cell phone. Hopefully the audio is good enough so that you can hear what I described above:
http://www.youtube.com/watch?v=EGkObHI7-bc (I turned up the volume higher at around the 52 sec. mark and then everything was OK)
just to make sure it is not a speaker problem, why not move the right speaker to the left channel of the amp. And move the left speaker to the right channel. If the noise moves to the other speaker, the problem is in the amp. If the left speaker still has the problem, there is a speaker problem.
I plugged in the Rear Right speaker into the Rear Left output of the amp and now the Rear Right speaker is popping, so it is definitely the the Rear Left channel that has the problem.
I have the schematics for the amp, so I am willing to open it up and try to track down the problem. What should I look at first?
I forgot to mention that I bought this amplifier from the Crutchfield Outlet store so it was a previous customer return. Maybe it has been repaired once already.
I unplugged the front and rear RCAs coming from the Head unit and the static/crackling was still there.Perry Babin said:That sounds like a head unit problem. What happens if you swap the RCAs (left to right)? Does the problem follow the RCA input?
You may have 2 problems.
I don't know how good the recording was but much of what I heard didn't sound like an amp problem. It could have been from overloading of the mic in the phone. It probably wasn't the best choice of music to hear the noise.
I heard something that sounded garbled/jumbled (as you described). That's not something that an amp can do.
Hmm, I do know that the ground connection of my head unit is bad so on strong road bumps, it will turn off for a second and then back on. Could this bad connection be the cause of the garbled sound I heard? Now that I think about it, could the following have happened?:
The ground wasn't making a good contact, so it was quickly opening and closing the circuit. Once I turned up the volume, this drew more current which was able to jump the very small gap and complete the circuit. This "soldered" the wires together enough so that even if I turned down the volume afterwards, it was still a closed circuit.
Definitely need to fix that ASAP. I need to get a harness to connect to the stock head unit cables for power. I just stuck the ground wire from my head unit into the plastic connector on the stock cable and held it together with tape.
Heres another video I recorded with a digital camera with somewhat better audio. You can hear the popping about a minute into the video and you can hear the hissing/crackling throughout the video.
http://www.youtube.com/watch?v=DQmSUBS9jHY
Perry Babin said:Did you swap the RCAs left to right to see if it made a difference in the channel that's popping?
Yes, I swapped both left and right RCAs and the popping still continued on the speaker connected to the left rear channel.
At this point, you'd need to get the amp somewhere where you can pull the cover and power it up to try to troubleshoot the problem (assuming that you want to try to repair it yourself).
Before you remove the cover, read through the basic repair page below (particularly the information in the yellow box).
I can't find a service manual for this amplifier so you'd need to post photos of the insides. I'd need to be able to read the text on the boards. If you can take high quality photos, email them to me. The file size limits won't allow you to post high res photos here.
babin_perry@yahoo.com
I bought the service manual for it already. It has parts lists, schematics, parts placement drawings and lots of other good stuff I'll send it to you in the morning since im accessing the site through my cell phone right now.
I'll try to get the pictures to you Wednesday evening or Thursday, since I need to borrow the digital camera from my friend again.
I took a look at your website and I'm impressed. Great information
Thanks for all your help so far.
With your meter set to AC volts (lowest range if it's not an auto-ranging meter), the black probe on one of the speaker terminals NOT used for bridging and the amp powered up, touch each of the 'outputs' on the connectors that connect the preamp board to the main board. Does the channel that was noisy in the vehicle show more voltage than the others?
They should all show ~0v. If one is noisy at the output of the preamp board, check the 'input' signals on those connectors to see if one is noisy.
If all are clean there (0v), the problem may be on the main board. Using a multimeter isn't the best way to trace a signal but this should give us an idea of where the problem lies.
Is the noise affected by the gain, crossover settings or any other controls on the amp?
Heres some data I got:
V= 13V DC
I(on)= 750mA (current reading on power supply)
Black probe on RightRear(-)
V(FR-OUT)= <0.1mV
V(FL-OUT)= <0.1mV
V(RR-OUT)= <0.1mV
V(RL-OUT)= <0.1mV
All the outputs leading to the main board are close to 0.
I also measured the voltages at the speaker terminals but they all said ~0.2mV, even the Rear Left, so my digital multimeter must not be able to detect the noise.
V= 13V DC
V(FR-OUT)= <0.1mV
V(FL-OUT)= <0.1mV
V(RR-OUT)= <0.1mV
V(RL-OUT)= <0.1mV
Perry Babin said:Does the amp make the noise out of the vehicle?
No noise so far. This is very wierd I am powering it with a variable (set to 13V) 3A power supply and I connected a 40W(total) PC speaker to the Rear Left output and I have not noticed the crackling/hissing that I had heard before. I have also not heard any popping. I am inputting sound from my computer. I can't turn it up too high since the speaker is not rated for much power and the power supply only has 3A of current. Ive turned it up so it draws between 2A and 3A, but it has not popped at that power level either.
I also tested all the power and audio transistors with an ohmmeter and there were no shorts between the pins.
I'm going to try putting it back in the car tomorrow and redo the measurements at the crossover board.
I don't see how it could be anything else but the amp that has the problem given that I swapped speakers and the RCA cables and the sounds were always in the Rear left channel.
- General Interest
- Car Audio
- Need help troubleshooting Infinity 7541a
