Hello
For the moment i have no caps
I search a good website in European union who sell condensators for a good price so if someone have this it will be cool
i search condensators of 4700µF/25V with dimensions for D 18mm "max" and Length is not "really important"
thanks in advance
thanks in advance
Hello Guys
I finish my smps but i need to find a pretty box for it
Do you think i can use a plastic box ? or a box like that
Galaxy 40 - 10mm - HIFI2000 GX248 - 40x230x280 - Facade 10mm Noire
I think the plastic will be more simple to use but i'm worry about the heat of each components
If you have other box to advice me please ?
I need theses dimensions inside the box:
width: 31cm
depth:28cm
height: 4cm or more max 6 cm
Thanks in advance
width: 31cm
depth:28cm
Thanks in advance
Hello
I've got news about my smps
I change the capacitors value who are in serial with the snubbers resistor.
On the original schematics it use 100nf, with the snubbers resistors who comes really hot "about 106°C and seems grow up..." and the output square wave on the primary winding is not perfect.
In fact i decide to use a 10nf capacitors with 22ohms 10w resistors snubbers.
Now the square have on the primary winding is better and the (resistors/transformers) have a temperature of about 49 °C after burningtest of 30 minutes.
In the next day i will build other smps
- General Interest
- Car Audio
- need help to build my own smps based on blaupunkt schematics gta400 please
