It's not enough to go on...
If it all works and nothings blown as such, then it might be a power supply fault... maybe an open circuit cap etc or a regulator fault.
Need to see a circuit really... no idea at all what the amp is. Is it stereo (2 channels) are both channels faulty ? etc etc
...the thing is that I took the broken part out(UPC1237HA: audio circuit protector for the speaker relay, and I've been waiting for the part). I am getting the audio output signals before the relay. The sound is normal, except the noise even I turn the VOL. down completely.
I cannot send the pic. from my email. Please help!!!
...how to fix this problem??
This is still not enough to go on. What type of noise is it you are getting.
Iain McNeill asked this right at the start.
Hiss, hum, buzz, squeals like tuning through the AM band?
well why didn't you say
It could be that the reason the protection module failed is because some other low power circuit has shorted, or got taken out in the process and the resulting higher quiescent current is producing more 50Hz mains stimulus.
Have a look around the sense circuits in the output stages to look for burned components - or in fact anywhere. Do you know why the protection module failed?
Or if indeed it has failed... maybe it's reacting to the AC noise on the output and doing it's job.
I asked earlier. Is this a two channel amp ? stereo. Are both channels humming ?
Does this help regarding posting a picture,
read post #254 make sure you "go advanced" when typing a message you want to add a picture to.
http://www.diyaudio.com/forums/troubleshooting/148984-bugs-13.html
- Need help reducing noise of Amp!
