Go to www.Digikey.com and enter the following in the parts search window (enter it exactly as shown below):
resistor wirewound 5W .33 ohm
This gives me 25 results.... They should all work, BUT I'm not exactly sure what your resistor looks like. There are different kinds of cases they can come in... I'm not sure exactly the one you need.
Its a more of a radial mount. Like the picture below. I looked at digi-key and the only radial mount is a special order. Can I use a axial mount with the same values? It looks like the exact replacment part can't be found through a traditional distributor.
___________
| NOBLE |
| RGC5 |
___________
___________
| NOBLE |
| RGC5 |
___________
