Need Help for Making a Part
Not sure why I'm replying, because I don't know what said part is that you need.
I want to say though: might it be something that could be "3D Printed" for you?
If so it might expand the possibilities of who can help. Search for 3D Print Service. I hear it's becoming less expensive. Antique car folks might hire a job for a car window crank for example.
Best of luck.
Making a part
I need to have a part done.
I could do it, depending upon how involved it is. I have my own Bridgeport milling machine but no lathe. I have access to a lathe but I would have to travel to Prescott which is a 40 mile round trip. Can you post a drawing?
There are machine shops all over the place. Have you tried finding one in your neighborhood?
Sincerely,
Ralf
Best of luck.
Alex,
Thanks for your input!
If I use acrylic, I can do it myself. But I think aluminum makes sound "punchier" and more dynamic, so I chose to use aluminum. I have limited power tools and can't make the part I need with aluminum. 3D printed is plastic, too.
Sincerely,
Ralf
Ralf,
Thank you very much!
I have checked with local machine shops. They simply don't want to do one piece at all. I don't think the part will involve a lathe.
Please see attached drawing. The numbers in red are important. The rest are not. They can be in tolerance +/- 1 mm or even bigger. If it is too much trouble, I can use my band saw to cut the blue areas myself. You don't need do it. These corners are really not important. They can be a little or smaller. I marked the dimensions just for the purpose of communication. You will have rough idea about these corners. I don't have any idea how you set up your milling machine. So, I can revise the design to fit your tooling and milling machine if you need. Material is 2024 aluminum. I can order a 1"x1.5" 1 foot long 2024 aluminum rectangle bar and send it directly to you. Please pm me or email me your shipping address and how much you will charge me.
Again, thanks a lot!
Jim
jimw10001 at gmail dot com
