I have a sony xplod 1252gtr 800 watt amp
Subwoofer Specifications
Is this amp capable of handling the subs at all let alone bridging them or do i need a beefed up amp. Would a capacitor help me out at all cuz my lights do dim as well with the system running, any suggestion on how big a capacitor i might need?
- 2-channel car amplifier
- 125 watts RMS x 2 at 4 ohms (170 watts RMS x 2 at 2 ohms)
- 340 watts RMS x 1 at 4 ohms (4-ohm stable in bridged mode)
- low- and high-pass filters (80 Hz, 12 dB/octave)
- variable bass boost (0-10 dB at 40 Hz)
- Subwoofer Size 12"
- Peak Power Handling 1200 watts
- RMS Power Handling 400 watts
- Voice Coil(s) Single
- Impedance (Per Voice Coil) 4 ohms
- Frequency Response 34 - 300 Hz
- Sensitivity 85 dB
- Xmax (millimeters) 15.1 mm
- Subwoofer Design Round / Circle
- Main Cone Color Black
- Woofer Composition Polypropylene
- Woofer Surround Urethane
- Subwoofer Grille No
- Re-Cone Kit Available No
