Hi, I've been here looking and reading posts for a little while now.
I am building a pair of two way floor standing speakers using no preset design. They are heavily braced and double wall thick mdf.
I was going to use a basic first order design for the crossover but thought it might be wise to get some advice here first.
I'm not sure if the drivers that i am using are a good choice but they are the ones I have and hope to use.
Please forgive the cut and paste of the drivers specs.
Scan speak
D3806/820000
Characteristic sensitivity (2.83V / 1m) : 90 dB
Recommended frequency range : 1 - 13.5 kHz
Free air resonance frequency, fs : 450 Hz
DC resistance, Re : 5.7 ohm
Voice coil inductance, Le : 0.04 mH
Effective piston area, Sd : 14 cm²
Moving mass incl. air, md : 0.90 g
Force factor, BL : 3.8 Tm
Excursion, lin./max. : ±0.4 / ±1.0 mm
Voice coil diameter : 38 mm
Rated power handling : 100 W (12 dB/oct.
cross-over at 1 kHz)
Net weight : 1.2 kg
Vifa
M21WJ-49-08
Nominal impedance [ohm] 8 SPECIAL FEATURES:
Voice coil resistance [ohm] 5.8
Nominal power [W] 80 Magnesium basket
Short term max power [W] -
Long term max power [W] - Excellent large signal
Operating power [W] 4 behaviour
Sensitivity [dB] 90
Frequency range [Hz] 25-3000 4-Layer voice coil
Free air resonance [Hz] 25
Voice coil diameter [mm] 32 Ideal for bass reflex
Voice coil height [mm] 13
Air gap height [mm] 6 Black coated paper
Voice coil inductance [mH] 1.7 cone
Eff. diaphragm Area [cm²] 139
Moving mass [g] 23.5 High damping rubber
Magnet weight [g]/[oz] 415/14.6 surround
Force factor [Bl] 8.9
VAS [l] 140
Qms 2.20
Qes 0.27
Qts 0.24
Thank you in advance for any advice that can be offered.
Mike
Scan speak
D3806/820000
Net weight : 1.2 kg
Vifa
M21WJ-49-08
Sensitivity [dB] 90
VAS [l] 140
Qms 2.20
Qes 0.27
Qts 0.24
Mike
What's the diameter of the Vifa? If it's a 21 cm, that's probably a bit too large to interface properly with a small dome tweeter.
First-order networks for two-ways can be used in very special circumstances, with drivers specifically made for that, a skilled designer, and a LOT of compensation. Even then, you normally won't end up with something that acts the way you think it will- there's a big difference between electrical slopes and acoustic slopes. In your situation, I'd design with a higher-order filter.
Thanks for the replys.
SY the vifa is an 8" and the scan speak is a 1 1/2" tweeter-mid.
So would these be suitable for first or second order crossover?
Vigier, I never really noticed the 13.5kH limit before. It won't really matter with 30 years of using power tools the upper highs are long gone.
