nearly complete stereo UCD400AD's (pics)
I'm no expert when it comes to caps and transformers either, but limiting current generally means you're cutting voltage too, because V=RxI. What I do know is that the voltage across a capacitor increases slowly when it's charged through a limiting resistor, but I don't know about transformers.
That's the whole point of the relay :) It switches between charging through the softstart resistor and going straight to AC, like in any other softstart circuit. The only difference is that this relay has a 220V AC coil connected directly after the resistor, so it'll switch over as soon as the amp gets close to working voltage.
I haven't checked if this actually works, I just think it should ;)
Soft start question
You guys are on the right track with a resistor in the line bypassed with a good relay. The first thing to do is to find one of the power supply inrush limiters that is suitable to substitute for a fixed value resistor. They should be available from any of the larger suppliers.
To trip the relay just use the rail voltage dropped with a suitable resistor. Putting an electrolytic across the relay coil allows adjustment of the delay to what ever you think is best.
Great looking amps! I do appreciate how much work all the metal cutting took.
Roger
Re: Soft start question
Roger
yep, thats what im kinda thinking. i want to keep it as simple as possible. i would love to offer a group buy for it that wouldnt cost a lot. it just sucks that you can buy a hypex module for about twice what a softstart costs. it doesnt make a whole lot of sense.
ill be starting a thread some day for a cheap softstart. maybe we can develop something flexible and cheap. something that could even be hand-wired on a PCB board too.
thanks for the compliments on the amp. they are breaking in now and are sounding SO much better. im very impressed.
