Hi Mal,
Nice to see you here!!
You can cut up the pcb to make modules, but then you have to make your own power supplies!! It is a fallacy to assume a monobloc will always sound better; it depends entirely on the topology. The NAKSA is made as monobloc amps electrically anyway!
Hope this answers your question!
Hugh
Hugh
Hi HughHi Mal,
Hugh
I'm after mono's easier to place in the room with the other amps.
Cheers
Cheers
Then you can use LifeForce (mono) modules instead.
Regards,
Andy
- More Vendors...
- AKSA
- Naska
