Good info, thanks!
S-Band is used for space mission voice. Well, gee, it's also used for satellite radio. While XM and Sirius content leave a bit to be desired, the voice quality is OK. And one might hope that NASA has better antennas than my car.
I am really beginning to think it's all an act. They want it to sound that way.
Here's some tech info on the Apollo radio with some links to more info at the bottom.
http://en.wikipedia.org/wiki/Unified_S-Band
The same is the case with jet pilot comms. With clear comms so important for safety, I'm sure if there was an easy way to improve it, someone would have made a big buck on it years ago.
From my experience in mil comms I can mention two factors:
- because of the high ambient noise they need to use either throat mikes or noise cancellation mikes. The first are very prone to compression and distortion, the latter may suffer from the cancellation process,
- there's a lot of electrical noise also. I remember in my work the all-pervasive 400Hz from the mains, both on all signals and as acoustical noise. Then add in all the digital noise, the radios and radars around you and you've got an EMI nightmare.
jd
jd
Heh, yeah I'm from Huntsville. Raised by a Nasa dude.
hmmm, is your last name Von Braun?
jd
A friend who used to work as a tank mechanic claimed to have made a line-level audio interconnect out of the cable connecting the headset to the tank. He claims speech is very clear but everything else is not there.
I agree with you. I did not get my point across well enough. The 70's solid state stuff was not the best for audio or so I've been told.Bas, so was the russian shuttle, Buran. But the computers they designed for it are still amazing.
And I was sort of trying to answer the
statement.can beam 100s of SD and HD video and audio channels
I reckon one or two LossLess Blackbodies would solve the rotten audio.So what's up with the rotten audio from the NASA missions? It has bugged me for years. Ever notice how bad it is? Why?
Blackbody - $959.00 : LessLoss high end audio power cables, audiophile power cables, audiophile cables
Perhaps a few in Houston too.
But they could be sold for 100x original cost. Because they will have been in space. With all the benefits of having been away from the earth's magnetism and the cosmic rays...etc., etc.Sure, but by the time that got into space, they would cost at least 10X that.
Actually I think they do. In the Navy at least a lot of wiring was teflon coated silver wire. I assume that if you use silver wire (Aerospace industry as well?) They'll use silver solder...I also hear that they dont use silver based solder in the analogue sections of the comms..
I doubt tank mechanic experienced 10G. Jets/spacecrafts realities way too different form what we get used here on solid Earth.
janneman explanation of the topic is clear and correct.
Not argueing about your post. Just that when the tank fires a round. The electronics probably get a very brief kick that is a lot harder than 10G I think.I doubt tank mechanic experienced 10G. Jets/spacecrafts realities way too different form what we get used here on solid Earth
Not trying to argue with anyone here, I see this thread as created for entertainment purposes, limited verified facts. Can't have an argument without facts.
I don't believe in cables compared to using other passive components to achieve heavy band-pass-filtering.
Anyway... did NASA fire new satellites or are they still using the old ones from Richard Nixon era?
This gives you an idea of what is still good, what is now bad and of course the ugly too, satellite version. Ping!
All available sizes | Big Brothers | Flickr - Photo Sharing!
USA - biggest polluter even in space
Actually Russia has more than double the dysfunctional satellites than the US, more total functional & dysfunctional than US also.
jd
jd
Or so they'd like us to think.
What if it actually wasn't the USA that won the Star Wars program?
Perhaps the audio sounds bad because there's a lot going on up there.
- General Interest
- Everything Else
- NASA Audio - why so bad?
