If nobody has an owners manual then can anyone tell me about the x-overs. Can it be used in a 3-way setup with ch 3/4 as a bandpass channel and if so is the bi-mode/tri-mde switch in the tri-mode position to do it? I'll figure it out on my own but if somebody out there knows i'd appreciate the help. I'd like to use it to run a 3-way (high/mid/mid-bass) front setup using the deck's front rca's and an Audiocontrol linedriver. Tanks
