This amp has a low level all the time no matter how much I crank it up. What could be the matter in your opinion? Bad caps? There's no humming or anything though.
possibly dust.
but I was thinking that when you rotate the volume pot it does not rotate internally inside the pot, (ie it is mechanically broken).
If you are good with a soldering iron try replacing the pot.
