My sand filled curved side walls project in progress!
Enclosure size is approximately 15.5 Liter
Sand will be filled at the bottom of the enclosure, sides, and back.
Here are some pics.
I'm having a hard time deciding which tweeter to use,
I have a pair of seas 27TFFC that I could use, or a pair of small heil ess tweeter.
I just took the heil tweeter out for a quick pink noise RTA to roughly see how it response, take a look at the blurry graph below
This is the tweeter just sitting by itself freeair, no baffle. Mic is 1/2 meter away held by my steady hand. It's unbelievably flat from 3khz all the way out to 20khz, much much better than most tweeters I've played with.
The drivers being used are the seas 27TFFC and the dayton rs150. Test crossover point is 2.21khz with 4th order. Ports are dual 2" x 8", it comes out to be around mid 50s.
I'll order some crossover components and start tweaking next week.
BTW, what do you suggest for the sand filling? Should I buy the sand bags from Home Depot or should I just go cheap and go to the beach?
The bass enclosure of my last project used sand filled walls- 12mm plywood inner shell (C-shaped, laminated from 1.8mm thick aero ply) and a 5mm thick fiberglass outer shell with an approx 20-30mm gap between that was filled with sand. This way i could get some really nice compound curves on the outer shell.
The sand made quite a big difference listening to the speakers filled vs unfilled, with the bass becoming a lot tighter and punchier with the walls filled, worth trying but not sure if its a big improvement over a ridgidly built "solid" cabinet. The weight of the whole speaker is well over 40kg though :)
For sand I would use the bags in your local DIY/garden center meant for kids sand pits normally called "play sand" here in UK, then make sure its all dried out properly by either putting in metal trays and leaving int he oven on a low heat for a while, or just air drying it. You might get mould problems if its damp. Some sort of fungicide might be a good idea too.
In my speakers I glued in a short (15mm) length of 20mm inside diameter steel tube into the back of the external shell into which I can insert a bicycle handle-bar end plug, thsi lets me top up the sand as it compacts down over time and leaves an air space at the top of the speaker.
Good luck, matto
Matto,
Thanks for the input of your experience, I don't really know what to expect from this experiment. The woofer is only 6", so I don't expect too much bass out from it. I'll try to break in the woofers for a few days and will fill the dry sand after to see if the bass improves.
I really like your project. Just curious, what drivers did you use? I'm spotting the seas TBFG? xls woofer and vifa mid?
spot on with the tweet, mid is a seas MCA15RCY and woofer is a Scanspeak 8555-01.
The woofers really shift some air for an 8", X-max is about 13mm as far as i recall, but even at pretty loud levels there is hardly any vibration present on the outer walls of the enclosure. I was amazed how loud it was when i pressed my ear up against a mission 782 3-way speaker with a much smaller 6.5" woofer how much of the sound is transmitted straight though the walls- in that case 30mm MDF- and its much less with the sand filled walls.
The mids were something of an unknown quantity when i got them as they were quite new, but some people like troels graveson have subsequently measured them and really rate them- which i would definitely agree with, they are very clean, natural mids.
ShinOBIWAN said:
I did something like this a couple of years ago now.
I bought something called kiln dried sand. It was almost white in colour.
Using regular sand may cause the MDF to expand because of moisure.
yeh, moisture is probably the worst enemy for sand filled enclosure. How exactly did you seal off your enclosure, though?
lufbramatt,
I suck at guessing drivers :eek:
Would you mind sharing the crossovers with me? Or at least the crossover points? I'm interested in starting another project with the drivers that you used. Since the bass enclosure is totally separate, I'm thinking of going actively with it and using a 10" instead. I have a rough idea of the design as well. It would be great if you could give me a few pointers in terms of design.
Kev
Administrator
Joined 2004
Where does the sand go? Under the curved piece?
Looks nice, should be very dead.
I have used sand (a long time ago) and baked it on a tray in the oven to dry it.
Yes, it gets hot! :hot:
Did do some sand filled cardboard boxes recently. Not bad....
hi
crossover points are about 360hz and 3.3khz, second order slopes on all the drivers apart from the 3rd order on the tweeter due to the shallow roll off and the relatively high xo point from mid to tweet. Crossover was worked out in Speaker workshop and tuned afterwards by ear as the treble was found to be a bit forward.
Ignore the bass region, some weird room interaction stuff going on. The 8555's are clean down to around 35Hz and are nice and tight, definitly not rolling off at 100hz like the graph suggests.
Overall impedance is 6 ohms with a little dip at 360Hz to 4ohms.
Thanks for the crossover Matt :cool:
I'll see what I can come up with the next design. Those drivers look like real good candidates.
*update on my sand filled project*
I got some industrial sand last night, dry but very dusty. The other types that Home Depot carried seem to be moist and I didn't want to deal with drying them out.
So far with only the bottom portion of the cabs filled, bass improved a bit. It does seem to extend down a bit more with definition. With only 2 small 6" woofers, bass is enough to fill my room.
I'm not sure if I should add more sand to the cabs, they feel like they're about 35-40lbs already. I'll listen to the speakers for a few more days to see how I should go about it.
