My project mod ebay frequency counter
i Build a 5 volt power supply
Based on LT1764
I added a BNC connector
CONN BNC RCPT STR 50 OHM SOLDER
And coax cable
TE CONNECTIVITY - RAYCHEM
5019D3618-9
TE Connectivity Aerospace, Defense and Marine
and Aluminum Case
Which I specially adapted
For him
Based on LT1764
And coax cable
5019D3618-9
and Aluminum Case
For him
more photo
Works pretty well
In addition I built
A small oscillator tester
I'll add to him a BNC connector later on
In addition I built
more photo
i add 9v voltage reg LM2940 to the oscillator tester
Good job Daaz.
I've bought this counter last year (very cheap on Ebay), but unfortunately it is not able to measure frequency below about 100kHz. I only read the bid too fast.
Anyway, it work fine (and precisely) above.
Frex
I can measure it with frequencies starting at 200 Hz
Enter the menu
Filter - Select Off
And select L mode (Low)
If you are in A mode ( Auto)
It measures from 100 kHz
I tried to switch off the filter too, but i don't remember to be able to measure
as low as 200Hz. I will try again then !
Frex
proof
I am now building an aluminum chassis
For the
Colpitts Crystal oscillator tester
That I built
I cut the aluminum
For the chassis.
I dril holes for the LED
And the BNC.
I painted
In a blue candy.
4 layers In the oven 50 degrees.
For the
That I built
I cut the aluminum
For the chassis.
And the BNC.
I painted
In a blue candy.
Almost ready
All that remains is to add the led
And connects to the power adapter
Almost ready.
I finally used my glass cutter for a purpose that not jast artistic
Mission completed
i Pierced holes the For screws
It's ready at last
It's ready at last
- Design & Build
- Equipment & Tools
- My project for building frequency counter
