My NON-discrete SODFA class-D amp
Perhaps it helps to realize that these are perforated board prototypes built to demonstrate the validity of the idea, not the actual performance.
Oke thanks, yes then it will go wrong, Have you never think of a bessel 24dB low pass filter?, I do not mention previous post..
Buy the way, is there somewhere a good model for the IR2110 chip? mine do not work, get 3 amps on SD pin and K-amp 0n VCC thanks in advance.
regards
