my new ampli mosfet
Where is R1, R2, C1, C2, T1, T2 etc ??????
I did not understand what schematic you referring, in any case I placed the new scheme updated
I am already using this software
The 1 MOhm resistor at input, should be more like 1 kOhm.
The gain of this amplifier is
330 kohm / 220 ohm = 1500
This is too much for any power amplifier :D
Excuse me, but where you see these two resistance? and how this gain calculations?
For 2x30 Volt supply, a voltage gain of 20-30 would be more like it.
Explaination:
As the output of CD-player can be almost 1 Volt RMS
you only make amplifier work to hard, in making more then x20 or x30 for voltage gain.
( amplifier can max produce like 20 Volt RMS at output )
Regards :) Lineup [/B]
yes, is exactly what I want to obtain, 20W of excellent sound amplified
I did only one mistake:
33 kohm/220 ohm = gain 150
Better use 33kohm/ 1k5 = gain 20
( or maybe 33kohm/1 kohm = gain 33 )
Switchercad by LTspice is good.
Now you run some tests with this software.
You will see that 1Mohm/47kOhm input should better be 1kOhm/47kOhm
regards lineup - please keep on xcicc .. this amplifier may be good .. in the end
I am here to check out your schematics. No worry my friend ;)
