My first try to build a mobile Headphoneamp.
I used the Datasheet/Shematic from the BURRBROWN BUF634. I only changed a little bit the overall Gain.
As battery i take 8 pieces of 3,7Volt Lithium with two charging moduls from Keeppower WYY-EBD02-AB - so i get +-14.8V (max. 16,8V min: 10,7V, while charging 17,5V) It plays round about 12-14h
The PCB i made was to build some headphone amp for home use.
size compare with my sony xperia:
case:
internal wiring (i'am not lucky whit the result, but considering that it was not planned as a mobile amp the result is not bad, i think so )
This is my first step in the world of "better" Headphoenamps. I'am very impressed how fine it sounds.
Next step - build an charging socket to load the Batteries easy
case:
Nicely executed, but it's neither meat nor fish.
A battery desktop?
Nice big shiny HEAVY enclosure. Why bother with the batteries?
Or build highly integrated with an enclosure no bigger than a mobile phone and be truly portable. This is where to go with CNC machining or 3D printing.
A battery desktop?
is that a custom milled enclosure or did you buy it somewhere?
very nice work!
mlloyd1
custom milled.
Looks first class to me, very nice job.
A battery desktop?
Why this Batteries? ... why not?
The point is this, in my job it's allowed since a few weeks to use headphones (reduce office noise) BUT it's not allowed to take some power for your private Stuff like charging smartphones or so .... now i can use my DT770 at the job, the Batteries hold up easy 1-3 Days ... easy to put it in my Laptop Bag ... that's the story why this mobile headphone amp ist not the smallest
- Headphone Systems
- My mobile Headphone AMP w. OPA134 & BUF634
