My Holton amp builds.
The 500L boards still sound awesome, big improvement on my system. More spacius and detailed, absolut recomended. Only reason for buying the R2 is for bass amp.
Im in love.
Im now running the boards with bias at 70mA for eatch transistor rail. Heatsink temp ca 43 celcius.
Anthony know his work !
Inspired by Holton and wanting to make the capacitor bank nicer im using plexi glass and drill holes for the cap.
48 pc 2200uF 100volt Nichicon KW for each channel.
Putting togheter a low budget 500R2 dual mono.
Used enclosure, used 500R2 and used toroids from Thule PA200 monoblocks
2 x 500VA 2x45 volt.
12 pc 10000uF 80volt Roe for each channel.
Soft start modules from Jims Audio.
Geofei binding posts.
Neutrik Gold xlr.
Cheap iec w switch and fuse.
Al ac is 2.5kv solid core cooper.
MIT speaker cable.
