My first DIY speaker
HiVi B3N
8" Concrete mold tubing
3/4" MDF
2" PVC pipe.
Total investment $27.50
Pretty flat all the way down to 100hz. A little spike in the upper mid makes them sound a little shouty, could definitely do with a filter.
They don't image or sound stage very well, but are clean and clear. This is just a quick and dirty test enclosure, not sure where I will go from here.
Zaph|Audio
not sure of the difference between your B3N and the B3S in Zaph's project
One has a round frame, the other a square. ;)
I've looked at Zaph's before and honestly all the little details he goes into was off putting for my first project.
I played my speakers all day at work today to break them in so when I got home I decided it was time to turn them up a bit.. Yeah.. At higher power they turn into a boomy, muddy mess. Another thing I noticed. The sweet spot is VERY narrow. You have to point both the drives directly at you for it to sound right. Off axis the highs almost disappear.
Ex-Moderator R.I.P.
Joined 2005
I consider that as a good thing :rolleyes:
but a small 80db 3" driver is ofcourse not intended for higher SPL
enjoy what its good at and worry less about what it cant do
but your box looks very big, and porting looks big
maybe its tuned lower than it likes to
you could try putting a sock in the port
btw, try to turn the box, so that the driver is either to the left or to the right, maybe it will change some
