My 10W Mono Single-Ended modules - D10.1
Ex-Moderator
Joined 2005
A board specifically for bridged operation would be best to keep the connection length and noise down, but it would kind of defeat the flexibility you have with monoblocks. Of course a board with two modules that is configurable for dual mono or bridged could be done pretty easily too.
Bridged modules probably wouldn't like a 4ohm load too much because their minimum load single ended is 4 ohms. They could drive 4 ohms at lower levels but won't have enough current for the full voltage swing.
Maybe this will stir up a bit more interest :)
I recieved my kits today and assembled them in about 40 mins.
Sorry for the crappy pictures... only tine for a few quick snaps. Will get better ones soon :)
Board layout looks good, and the PCB's are of excelent quality. Will comment on sound fairly soon.
Ex-Moderator
Joined 2005
Anonymous, the AMP3 is still one of the best amps for the money right now.
I'm working on altering the enable circuit, enlarging the mounting holes/pads, moving to a surface mount inductor, and changing the layout a little. I only need a pair of amps for testing but it's more economical for me to have a minimum of 10 boards made. Thus, there will be some more kits available soon that have these changes.
I dont think the mounting holes need to be enlarged.. The fit my M3 screws and standoffs perfectly.. :) The mounting holed by the capacitors could maybe be moved a tiny bit away from the zener diodes. If the heads on the machine screws were much larger than the ones I've used, they would be contacting the pads.
I didn't run into any problems with assembly due to layout, it goes together nicely.
About going to a surface mount inductor.. Would you still be sticking with a toroid? I've got some 10mH SMT toroids here.. The problem with them is they lay down, taking up more space on the PCB. I Do they make any that stand vertically? I haven't seen any but that doesn't mean they don't exist.
Ex-Moderator
Joined 2005
The mounting holes will be enlarged a little bit but the pad diameter will be a good bit larger to accomodate screws with larger heads.
The inductors I've been looking at are shielded ferrites. So far they sound just as good as the toroids but I haven't been able to check out any waveforms with my scope to see how they compare when driven hard and in terms of EMI. The ones I've tested are 13mmx13mmx8mm and that is why I have to change the layout a bit.
They do make surface mount toroids in both lay down and stand up packages, but the lay down toroids take up a lot of space and the stand up surface mount toroids are pretty expensive.
Ex-Moderator
Joined 2005
No jumper. When you power up the rails the amp should just turn on.
Everything looks right from your pictures. Do you have the LEDs in the correct way?
More importantly, is power hooked up to the correct wires? Are the modules drawing any current from your supply?
V- should be -12V, V+ should be to +12V.
With 12V rails you should see about -7.8V on pin 4 (the enable pin).
Ex-Moderator
Joined 2005
Here's a little update on this project.
I've redesigned the boards for two different kinds of surface mount inductors. I've tested the them with the one sample and it works just as well as the toroidal inductors. I've got some samples of another type on the way and will try them out soon. I'm going to have maybe 30 boards made that will use the one inductor I think will work the best. I'm will build 4 modules for testing and about 4-6 other boards are spoken for, so that leaves about 10-11 pairs of modules left if anyone would like to buy and build up a pair. I'm asking $55 shipped in the US ($60 shipped outside the US) for a kit which includes all the necessary parts to build up two modules. You would need to find, build, or buy a +/-12V supply to power these little guys. I should have all the parts and boards in a few weeks. It will then take me a couple to a few days to transform the parts into kits.
If you're interested please get in touch with me via email.
Ex-Moderator
Joined 2005
How's this? I ran out of blue so I had to use red and green on my test modules. The green ones need more current to be at a similar level of brightness. I still prefer the red or blue LEDs, even though the blue ones are a lot more expensive. Blue is a more soothing color and is generally associated with cool things (temperature wise). Since the chip runs so cool it only seems appropriate :)
