mutt clone in the works
This is my verison of the wilson puppies. I thing the standing waves are mostly dealed with. The baffle is kinda giving me hell. The bottom corner are curved,so I will have a sculptor finish it. Next I will cut the hole for the driver(seas1189 or the special buy MB Quart and a RS180)
I Have a choice of two finishes for the high-mid baffle.
1. Use faux leather
Or
2. painting the baffle. More of the baffle is edge
a. Do I seal with bondo (also use the fill screw holes?)
b. Water and glue
c. Use spray sealer
d. Use just spray paint, I have about 30 can of enamels
Different colors last 6 coats will be black
Since I got no reply for my last two posts, I assume one method has no advantage over another,
I going with the faux leather and the oval bracing. I came cross 10/$1 ceiling fan extend poles. I in the process of finishing stands for the Hi/Med enclosures.
Here is a picture
homemade damping sheet
Added my homemade damping sheet today. It is TP4 (roofing material), butyl rubber, siliconized acrylic and eggcrate foam. I give the enclosure the “rap on the side test” with and without the damping material. Let’s just say the difference is very large. There is a much deader sound.
The TP4 is $54 a roll at Homedepot. You can also get scrapes from construction sites with office or warehouse construction…
If you can get pieces of TP4 for free, then the damping is cheap about 10ft for around $10 maybe less.
The butyl rubber and the siliconized acrylic can be found for $1 ea. The eggcrate can be found for $1 to $4
