MUR860 Full Bridge Rectifier
Joined 2011
18V secondary would give about 24.5V after rectifier voltage drop.
I will be using good quality high temp capacitors at their rated voltage well below their temperature rating.
Nelson Pass F4 power supply schematic shows 18V secondaries and 25V caps.
Do not use Schottky diodes in this application -- they aren't meant for it, and it will bite you (Very low breakdown voltages, and the fast switching speed will cause noise). I suggest simply going with a good old fashioned potted can -- they are indestructible, match thermally inside due to their construction, and are heatsinkable, unlike individual diodes.
