I will be building a DAC / streamer that will have 3 power transformers feeding 3 power supplies and I'm looking for examples or advice on how best to wire the transformers to a power switch.
My previous projects only had 1 power transformer so wiring was more straight forward.
My plan was to go from IEC connector to a fuse then to power switch and from there to the transformers.
Do you use some type of power distribution block after the switch or just solder and heat shrink all the hot wires together?
I will be using (3) Avel Lindburg Y23 toroidal transformers.
Do you recommend a separate fuse for each power supply?
Thanks for the help!
Scott
Scott
