Finally some progress
It's working... Now I can place them on a bigger heatsink.
-By jaudio-
How many paralllel module are you planning with 50 chips?
I understand that you need to buy 50 chips to match the quantity needed for a stereo amp? 6 out of 50?
veteran said:Jaudio, I will make one stereo amplifier . I just need more chips to match them. I can sell the rest.
BPA200
Why match the chips? do you match for the lowest individual offset? and if so why?it is a componding rule that applies to the DC offset, you will net gain for the lowest level of offset, but you will still have DC and higher idle dissipation, I would be curious to know what youre Idle current per chip is becuase idle current can be more of an issue then DC offset. Just take the normal 60ma per chip and mutiply by 3, I will bet ya its a lot greater then 60ma*3
veteran said:PierreG, I just wanted to match them proper .
Do you mean that you can make the board without matching the chips ?
What would append then?
- Chip Amps
- Multi-chip amplifier - Concentra, GC, PBA200, multichannel (all in one)
