Joined 2009
I've seen some discussion on stereo and mono but very little on multi-channel. If you were designing an amplifier module for use in a multi-channel system with unbalanced inputs (e.g. HT), what strategy would you employ for ground lift (do it on each amplifier channel, do it once by ganging all the input signal grounds where they enter the box etc) ?
I think it's safe to assume that there would be a lot of cases where only a single-source is involved (in my case a Blue-Ray player).
