I put 47 ohm gate resistors in the amp..
With just power and ground hooked up the fets blow..
I replaced the 2N3906 drivers but the amp still blows fets with just power and ground hooked up..
If i remove the fets Do i put a 1K resistor from Drain to Source or gate to drain or gate to source ??
Just wanna look at the drive signal loaded down to see if i get a nice square wave
Ok the 494 wasent the problem
There is a IC in the power supply marked HS108P-J
It connects to the gate leg of the power supply fets I'm guessing it's defective and cannot find a replacement for it through any suppliers
Is there a way of testing it or jumping it to see if it's defective for sure or a suitable replacement for it?
Do I need to supply more info on the amp?
- General Interest
- Car Audio
- MTX TNA251
