MTX Thunder 5601
Install shunts on the preamp board connector as shown (after confirming that there is no DC on the pins). With the jumpers in place, does the amp produce audio?
TL072C
Pin 1:-15.36
Pin 2:-15.37
Pin 3:0.00
Pin 4:-15.31
Pin 5:0.00
Pin 6:-15.31
Pin 7:-15.52
Pin 8:-15.52
Also R318 got hot a came unsolderd from the board ..
Its a 100 ohm resistor?? Just trying to confirm
If the op-amp appears defective i will replace it ..
Have a few things to do so ill work on this amp later tonight
The resistors that typically fail are 10 ohm, marked 10R0 and are connected to the power supply pins of the various op-amps.
If you replace all of the defective resistors and you don't get clean audio, see if any of the op-amps are heating up or if you have more DC voltage across any of the 10 ohm resistors (possibly indicating that one op-amp is drawing more current than it should).
Perry,
I get clean audio from the amp with the jumpers installed..
I removed the jumpers and plugged the pre amp board in..
The pre amp board is dead i get no lights on the display for the pre amp board and the amp doesnt have output with the board installed..
Any ideas what to check next?
