Mtx terminator tna251 help.
So the blew all the ps fets, and probably the outputs too. Legs 2-3 are shorted on all output transistors. The amp had 75n06 in the power supply which i switched for 3205's and in q1-4 replaced the drivers with mps56-06? The amp powered up however i left it on 9v and it drew over 3amps.
Board.
I know this is the old thread but I just acquired MTX tna251 the board looks similar to the board y'all have posted but it is a little different the amp just flashes the red light when it's connected to power I took the cover off and there is a resistor in between two of the capacitors that is blown but I can't read the board to know what to replace it with does anyone have a circuit board diagram for
