Those are in series with the transistor that's used for the +15v regulator. The regulator may have failed. Check all components in the regulator circuit.
There was a high failure rate for the 540s. They may have used the 150v transistors for a reason. The IRF3415 may be a better choice and is likely to be more reliable than the 540 (rated for both higher voltage and current).
